5mm spacers fit over the hub built in the brake disc center, with an inverted conic hole which fits over the flared base of the hub. They won't fit in reverse due to the shape of the hole
When fitted, original wheel bolts still had about 2cm of thread to go into the disc
Track increase by 10mm seems to produce some effects, although the road was wet and my summer tyres do not cope very well, still it appears to have got a slight oversteer at a sudden turn-in (maybe on dry road the tendency will be compensated to neutral). As I have always wanted a neutral car, it seems now over- and understeer balance each other
Later Edit:
Finally got rid of understeer, at least for reasonable speeds. After 3 years of laboring and spending, the Leon truly drives like my 1966 VW Beetle on twisty roads... and it's still on factory springs and shocks, and has no rear aftermarket ARB
At motorway speeds the steering becomes
very light after the front track increase - it steers literally at the lightest kink of the steering wheel towards left or right. It's the only thing which can influence in a negative manner the stability of the car
~Nautilus
