There aren't brake lines, wires or ducts inside the subframe
I had some weird ideas to stiffen the subframe without welding (which is invitation for rust): "seam-welding" with epoxy resin in the seams between welded spots, foam inside, aluminium cage etc
Right now I run a Wiechers lower tie-bar on the subframe, augmented by upper Wiechers strut brace, and a Powerflex poly+rubber dogbone, but it still doesn't seem "stiff as a M3". (And I'm not fond of E36 M3s, the league to aim for is Lotus Esprit-like chassis construction and manoeuvrability, weird as it sounds
If everybody is sure the non-LCR Leons run on Golf-like soft one-piece bushings, then TT bushings are the next step
~Nautilus
~Nautilus
