hi guys, the other day the car started messing around, when i came to a stop the car wouldnt start and when i did the revs were all over the place.
tonight it did the same but before i turned the car off i noticed that there was hardly any boost and the turbo wasnt spinning up like normal, also when i put my foot down on the gas there was i big hesitation, so i pluged it in to vag.com and it came up with .....
1 Fault Found:
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-00 - -
i have checked for leaks and couldnt see anything, would it be the DV or could it be something els, such as boost controller, wastegate, actuator or turbo unit.
please note i am using the standard DV
thanks for listening david
1 Fault Found:
P1297 - 35-00 - -
