When manufacturers quote 0-60mph they dont do it from the speedo.
0-60mph on speedo is really a 0-56mph test.
My LC does 60 in 2nd? when i read this i went and checked again, it really does!! will try and get a clip, and post a rough 0-60.
ok, so im being a bit flippant here but i would like to know the mechanical reasoning behind it rather than just figures stated by a tuning company trying to seel an upgrade product.
Who has ever said the 6sp box cant do an indicated 60mph in 2nd?
Yes it will, but it only equates to 56mph.
manufacturers do not do a 0-60 off the clocks FFS:rolleyes:
Mechanical reason for what? Gear ratios? Dont get your point?
Most 6sp boxxed cars cant do 60 in 2nd. I had a CTR beforehand and that was exactly the same!
mitchy, your link also states that the top speed in 6th is 168....wanna explain to me why the lcr doesnt do that?
Not enough power, box shaped, aerodynamic drag for 1.
Dont take the brains of einstein!
222bhp is not enough to overcome aerodynamic drag for 168mph.
You need a good 350bhp+ for that.
Here, to bury this once and for all and to stop skahigh arguing black is white.
Here is proof....
http://www.seatcupra.net/forums/showthread.php?t=100070
J@mes has increased limiter and 280bhp. J@mes does not have 222bhp and standard set limiter.
And yet still his limiter kicking in at 59mph.
THANKYOU!!!!!
Professional timing equipment used.
ok, ive done some research and heres what i've found:
lcr diff ratio = 3.88:1
lcr 2nd gear ratio = 2.11:1
(http://www.supercarsite.net/seat/leon-cupra-r/2001)
standard tyre circumference = 2001.82mm or 78.81 inches (http://www.alloywheels.com/tyrecalc.asp)
inches per engine revolution = tyre circumference / (diff ratio X gear ratio)
inches per engine revolution = 78.81 / (3.88 X 2.11)
inches per engine revolution = 9.627
lets say 7000rpm...
7000 x 9.627 = 67386.85 inches per minute
multiply by 60 = 4043118.19 inches per hour
divide by inches per mile (63360) = 63.81 miles per hour!
lost 400bhp on last year (on a borrowed engine after major blowup)
as boxy as a box stuck to box car
drags so much paint comes off
but still does over 160 in 2nd :lol:
just thought i'd lighten the mood a bit :p ill get me coat :redface:
is this not a forum for discussion mitchy? or should we all sit back and let you tell us everything we would like to know about our cars?
i have NEVER said that i am sure that the lcr will do 60 in second, i only want to know WHY it wont!
the stats i have posted up show that in THEORY it is possible not counting for wind resistance etc.
I can answer this... it wont because the gearing will not allow a true speed of 60mph. It falls just short. Even if you over-rev and go beyond the point where your car stops making power, the speed wont hit 60.
Increasing power doesn't change the gearing either, it just helps you get to the same point faster ;)
