robbob
Leon Cupra
Jul 24, 2008
99
Portsmouth
Evening,
My traction control light randomly comes on and stays lit until the ignition is turned off and on again, happens once or twice a month. Scanned car with vagcom came up with this code:
01435 - Brake Pressure Sensor 1 (G201)
008 - Implausible Signal - Intermittent
Would i be correct in saying that it is the brake pedal switch that needs replacing? Or would you say its something more serious?
Rob
Hi yeah sorry, i realised that after i posted. I am working away from the car at the moment so i can't do a full auto-scan. The car is a 2001 Leon Cupra. Thanks
Took my time but tried to do a autoscan today and would not work fully. (using shareware version and ebay cable) ABS module is MK60 tho. VCDS-Lite Version: Release 1.0
Sunday, 01 August 2010, 16:15:12.
Chassis Type: 1M - Seat Leon/Toledo
Scan: 01,02,03,08,15,17,19,22,35,36,37,46,56
Address 01: Engine Labels: 06A-906-032-AJQ.LBL
Controller: 06A 906 032 DE
Component: 1.8L R4/5VT 0001
Coding: 11510
Shop #: WSC 06441
1 Fault Found:
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: Redir Fail!
Controller: 1C0 907 379 E
Component: ESP FRONT MK60 0103
Coding: 0019970
Shop #: WSC 00001
1 Fault Found:
Thats what an autoscan brings up.
