1.2 tsi The starter does not spin
May 1, 2020
7
Hello, I have Ibiza 1.2 tsi from 2014. The problem is that the starter does not spin, and the controls work properly. Good battery and there was an attempt to start from another car and no changes. I have an OBDeleven and VCDS application. What could be the reason? He has traveled 68,000 km.
RUM4MO
7,784
983
South Scotland
Maybe forget about scanning tools and try to get the starter to operate by powering the solenoid from a temporary suitably fused wire from the battery, if the starter does now operate as expected, then at least you know it is just a control wiring issue. I'm guessing that you are not getting any warnings about the clutch pedal not being pressed fully down?
May 1, 2020
7
Hello.The car fires without pressing the clutch.
but in the obdeleven and vsdc application there is something requested for the starter and other names. and wysztkie shows 0 and how will I try to light it should be on 1?
Could you draw in the photo or indicate how to check the starter?
dm222
1,468
46
check the thin wire that goes into the starter
Reactions: Wanjo1
dm222
1,468
46
maybe even try to disconnect the connector and conect again...
tip: you need to push the red part of the connector in the direction of the wire to unlock it, and then again while removing the connector.
a bit differente here, but some example:
May 1, 2020
7
Hello, sorry to speak up now. The car has been repaired. There was a broken cable to the starter.
P.S such a question is it normal that the fan does not work in the climatron in the ignition on? It works like I start the engine. And will it change the coding?
