Hi all
Leon mk1 1.8 20v non turbo. 2003.
Car won't start.
Story is, car has always had the characteristic VW starter motor whine after start. So I decided to change it. Got a new Bosch one. Fitted it, car started up ok first time, I literally started it to check it was working and turned it off.
Next time I went to start the car, it just wouldn't go. Crank it enough and the oil pressure light starts flashing.
Tried using jump leads thinking maybe battery was short on voltage, no go. Battery was tested the day before I took it off road by a motor factors and it was found to be spot on. Still 230 or something cca with a 260 from new so battery is good.
Starter motor seems fine, turns the engine over, belts are moving. Is it just not powerful enough? Although I'd still have thought, if the engines turning, its gonna start, the starter doesn't need to go a particular speed.
I had a broken pipe on my inlet manifold which I thought may have been causing the issue but now I've replaced it, the problem remains. I also have an exhaust manifold gasket leak which has been making me overfuel by 14% on my long term fuel trim for a long time, months.
I've tested for spark and cylinder number 4 is firing ok, haven't tested the others, but couldn't smell any fuel from the bore after the test or see any dampness on the piston. So I think I'm getting no fuel. Fuel pump is priming. I've tried removing the fuse for the pump and cranking with a wide open throttle to clear any flood and replaced the fuse, reprimed a few times, and still the same.
I'm guessing most people here know these cars very well so has Anyone got any ideas what could have gone wrong? I can't see any wiring damage anywhere. I've put all necessary connectors and sensors back how they should be, not new to mechanics, been doing it around 15 years so know my way around an engine. But I'm buggered if I know what's up here
I have a Snap on Solus scanner and have checked for codes. I did get a 18010 Power Supply Terminal 30 Voltage too Low P1602 Intermittent DTC last time I connected it which was when I first got the trouble about a week ago.
Last thing to add, the last time I tried to start it, when I turned the key, the door locks blipped back and forth. Also, for a while now, when I start the car, the stereo has been resetting its memory. The ground seems fine to me, checked for resistance between engine and battery negative, all good. Battery negative terminal is a little bit loose, as in you can't take it off, but it does turn if you move it with enough pressure. Could it be as simple as that terminal is borked?
Also, when the stereo has been resetting, the car has been sluggish to turn over at first. And has often needed throttle to get started from cold. Which I hope the vacuum leak I've fixed has resolved if I could only start the car.
Sorry to waffle on, thanks for any help and encouragement.
Car won't start.
