10 mm spacers on back wheels MK3 IC
Dan_Cupra
61
can you put 10mm spacers to sit back wheels out a bit more? can you use standard bolts or would you need longer bolts? thanks Dan
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
minnimum hubcentric is 15mm on rear as the hub spigot itself is 15mm thick.
longer bolts or studs/nuts conversion. wide spacers 25mm and up can be bolt on type so std wheel bolts can be used.
20mm spacers possible on std 6x16 rims
