no you can't..
but you can get a clue, do a log of block 020,002,115 for cf timing maf reading and boost , fourth gear start from 2000rpm all the way to the red line. pedal to the metal :)
and post it here.
Logging these blocks will not tell you anything about fueling which is block 031 btw. His car would hit limp mode if there was a big difference of boost above what was requested, in addition this was probably mapped out, more than likely the sensor is bad, I would take it out and clean it before replacing it.
you will always have oil in the cooler and pipes ;) as long as its not loads your ok
