V6NUT
Guys I needs some Help
I keep getting this fault code. This throws up the EPC light and cuts all the power until i switch the ingnition off/on. This is happening randomly always on part throttle.
I've done a search on this and found a few threads but nothing to confirm what resolved the issue.
I think the car has been mapped but unsure of what it is. There are no other mods apart from this i believe.
Any help you can give will be great. :)
Thanks.
Hi Dave
I think it is mapped but I have no idea what map is on it. I know that sounds vague but it does feel like it's boosting a little hard for a standard car.
I had a look at that thread but nobody came back to say what resolved the issue if anything.
If i knew what MAP it was i could have at least tried to contact them to see if then knew of the issue.
The MAF is standard but is new. The last one got stolen (long story)
The MAF came from the dealer however I can swap this with the other half Ibiza and see if I get the same issue.
I'll also go over over all the hoses and check for leaks. If there was a leak would this not cause a loss of boost? However i can't say what it's boosting anyway as I haven't got a gauge fitted yet.
Is there someway to log this in Vag-com? I have Vag-com but i'm not that clued up when it comes to logging etc.
Thanks Dave Scotch Corner isn't that far i work in Darlo :D
Kash
Kash
Yes some Vag-Com logs would be well worth doing . Let me know when you want instructions on how/what.
You work in Darlo - my condolences. :D Mind you, I work in Hartlepool :cry:
