205/45/17 instead of 215/40/17 on FR?
lefkon
108
Time to change tires and I've been thinking on putting 205/45 instead of the stock 215/40 on the OEM rims. What do you think? Have any of you tried it?
jellybabybandit
170
Tyre size is that for a reason. I wouldn't recomend it. For instance I am looking to replace my tyres on my 2.0 FR. I want uniroyal rainsports however been told that due to the extra weight from the 2.0 tdi lump we need the Extta load tyres
jimbo1876
43
660
Washington Tyne&Wear
nope it will mess with your speedo it will show less speed than it should by 4 mph etc etc
I was going to do this as the tyres I wanted where 100 quid cheaper but didnt bother stick with what the book says..
lefkon
108
OK guys thanks for the advice. Its just that the guy at the shop suggested it saying that he has put 205/45 on a golf that takes 215/40 and it drove better. Personally I don't think it would drive better. If at all it would be worse.
DEAN0
Old Git
Feb 1, 2006
5,297
305
Preston - UK
215/40R17 tyres are appx 604mm diameter
205/45R17 tyres are appx 616mm diameter ( you would be travelling faster for the same engine rpm and gear )
nearest tyre size would be a 195/45R17 which is appx 607mm diameter but is probably too narrow for a 7.5" rim
nightflight
2,677
12
Sheffield
I'd advise against it on one key reason.
The 205s wont protect your alloys from kerbing, whereas the 215s will.
Learnt this lesson the hard way when I thought it'd be a handy cost saving by getting the 205s
