2ltr 8v (2E) mk2 Gti won't turn over or start.
rich.h44
Its a secret!!!!
Aug 31, 2007
1,601
hull
ok then, what about replaceing the earth's they may be coroded inside and the contact mat may not be good enough
G223
303
There should be an earth on the battery that routes rounf to the battery, is that ok? have you removed and cleaned its terminals on both ends? it defo sounds like a bad earth as everyone has said or a dud battery, it may read 12v on a multimeter but it may not have enough amps to crank the engine over which could also mean a shagged alternator but it seams unlikley its a battery from what youve said, try putting jump leads from the negative terminal on the battery and put the other end onto your engine somewhere, i think theres an engine hoist mount at the rocker cover gasket that would be perfect, this will tell you if its a bad earth or not as it will basically replace the earth lead.
Dolly_Gti
G60 spooling up.
Aug 15, 2006
1,412
china town
consider everything runs off battery voltage, lets say thats bang on 12v... you say at cranking youve got 5v? your losing 7v. either something in the starter motor circuit is nakerd, which is basically your powers/earths from battery ect. or the starter is nakerd but from the symptons id go with the masses, earths.
just double check your spare battery isnt duff, does it bump start or can a friend get their car with some jump leads.
CARL BRIGHTON
Chicken Choker
Jan 8, 2002
316
Gainsboro
right, i think ive isolated at least one problem to the starter as theres a strong smell of burning electrics coming form it after turning the key a few times....
only one problem....one of the nuts is rounded and looks like its welded itself to the stud
[IMG=http://www.facebook.com/photo.php?pid=58104&id=1135187543]pic[/IMG]
sorry...bad camera phone pic
but just in case, ive got a new ecu relay and coil to go on as well
CARL BRIGHTON
Chicken Choker
Jan 8, 2002
316
Gainsboro
righty ho..
git the new starter and bits on...vag com says:
VAG-COM Version: Release 409.1-S
Chassis Type: 6K - Seat Ibiza
Scan: 01,02,03,08,15,17,25,35,56
Address 01: Engine
Controller: 037 906 024 AP
Component: DIGIFANT 1.7 1729
4 Faults Found:
00525 - Oxygen Sensor (G39)
03-10 - No Signal - Intermittent
00524 - Shareware Version. To Decode all DTCs
03-10 - Please Register/Activate - Intermittent
17978 - Shareware Version. To Decode all DTCs
P1570 - 35-00 - Please Register/Activate
00518 - Throttle Position Sensor (G69)
31-10 - Open or Short to Ground - Intermittent
Readiness: N/A
Skipping Address 15-Airbags
Address 25: Immobilizer
Controller: 1H0 953 257 B
Component: IMMO VWZ3Z0S0285916 V00
Coding: 09600
Shop #: WSC 05811
No fault code found.
