300bhp Cupra R
sambryant
RoadRunner meep meep
Mar 26, 2009
4,848
Bristol
yeah 3" downpipe. hybrid turbo or big turbo. uprated engine rods. badger5 tip. wmi bigger injectors. fmic. good mapper. this will see you upto 330-340 bhp
rk696
683
West Yorkshire
Yep.
AFAIK, the most you will get from a maxxed out K04 turbo will be around 280, even with a full turbo back exhaust.
Lot of money to spedn for an extra 20 odd bhp..
Pyro
there are clams of 300 bhp from KO4's but im sceptical i bet the G/S readings dont match it ;) but as sam said you need the lot mate :(
itfben
DsignVinyl.com
Oct 24, 2009
2,000
nr. Tunbridge Wells
Dnt wana be buggering around with new turbos, or rods as its not a spring chicken (over 80K) on clock so not worth the money, a lcr with 40k on the clock might have the buyer pay the extra but with higher mileage it aint guna happen. Il stick with the acclaimed 260 snd bang a full 3" zorst system on the ol' girl. Maybe TIP n Induction
vwtrellis
300 is not possible from a standard ko4.. speaking to a well known turbo company a ko4 is out of puff at 260 bhp. so my 280 is a load of bull as well. ill go on a set of rollers any day with someone who claims 300 bhp just not ones that either of the cars have been on so its fair!!!
JamJay
California Bound
I'd disagree that the k04 is maxed at 260bhp, developments have happened (thanks to Badger 5) in the last 6mths that have unleashed more potential from the turbo and a few of these 'heart breaker' dyno's are consistenly coming back with 280bhp+ figures now. The best way to tell is via airflow logging on the road, mine comes back regularly with 226g/s which equates to between 282bhp & 287bhp.
Pyro
260?? Well thats bolocks ;) we can see that 280-285 is achivable by looking at sam bryants G/S readings so that company is chatting **** I'm afraid think one of the ko4's has 225-230 G/S withch works out at 281.25 - 287.5 so well over 260 ;)
Pyro
Sam's is making 285 on bill rollers ;)
Pyro
i got 287 from deviding 230 by 0.8 = 287.5 so give take a few eitha way
Apr 22, 2010
505
Leicester
what does that make mine then? dont get this :p (228.67 is the highest the g/s goes to)
Group A: '002 Group B: '020 Group C: '115
RPM Load Inj. On Time Mass Flow Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization RPM Load Absolute Pres. Absolute Pres.
TIME TIME TIME
Marker STAMP /min % ms g/s STAMP °KW °KW °KW °KW STAMP /min % mbar mbar
0.29 2520 32.3 2.72 15.69 0.6 0 0 0 0 0 2480 32.3 970 990
1.21 2960 69.2 7.14 44.17 1.51 0 0 0 0 0.91 2760 58.6 970 1000
2.11 3040 15.8 1.7 5.94 2.41 0 0 0 0 1.81 3360 45.9 970 1150
3.02 2240 68.4 7.14 33.61 3.32 0 0 0 0 2.72 2280 48.9 970 990
3.92 2600 66.9 5.1 34.69 4.22 0 0 0 0 3.62 2520 72.9 1040 1130
4.83 2880 49.6 4.42 23.03 5.13 0 0 0 0 4.53 2800 66.2 970 1190
5.73 3080 39.8 3.74 22.19 6.04 0 0 0 0 5.43 3000 47.4 970 1070
6.64 3120 23.3 2.04 12.47 6.94 0 0 0 0 6.34 3120 29.3 970 1020
7.54 3160 31.6 2.72 19.94 7.85 0 0 0 0 7.24 3120 31.6 970 990
8.45 3160 22.6 2.04 13.78 8.75 0 0 0 0 8.15 3160 25.6 970 1000
9.35 3320 63.2 6.46 43.64 9.66 0 0 0 0 9.05 3240 60.2 970 1010
10.26 3160 15.8 1.7 5.25 10.56 0 0 0 0 9.96 3480 48.9 970 1200
11.16 2560 109 11.56 63.75 11.47 0 0 0 0 10.85 2840 93.2 1840 1020
12.07 3000 191.7 20.4 151.42 12.37 0 0 0 0 11.77 2840 171.4 2260 1740
12.98 3640 191.7 21.42 157.28 13.28 0 0 0 0 12.67 3400 191.7 2300 2270
13.88 4280 191.7 21.42 184.67 14.18 0 0 0 0 13.58 4040 191.7 2320 2260
14.79 4880 191.7 20.74 200.53 15.09 0 0 0 0 14.48 4720 191.7 2330 2360
15.69 5480 191.7 21.08 219.11 15.99 0 0 0 0 15.39 5280 191.7 2270 2280
16.6 5960 191.7 19.38 225.44 16.9 0 0 0 0 16.3 5800 191.7 2230 2180
17.5 6360 181.2 17.68 228.67 17.8 0 0 0 0 17.2 6240 191.7 2110 2080
18.41 5920 13.5 1.7 0 18.71 0 0 0 0 18.11 6480 48.9 970 2540
19.31 4560 15 1.7 11.19 19.61 0 0 0 0 19.01 4920 14.3 970 1090
20.22 3200 13.5 0 8.39 20.52 0 0 0 0 19.91 3640 12.8 970 1010
21.12 1960 15 0 5.61 21.41 0 0 0 0 20.82 2360 14.3 970 1000
22.02 1200 16.5 1.7 3.25 22.33 0 0 0 0 21.71 1320 15.8 970 990
22.92 960 17.3 1.7 3.22 23.23 0 0 0 0 22.63 1040 18 970 970
23.83 800 19.5 2.04 3.06 24.13 0 0 0 0 23.53 840 19.5 970 970
24.73 760 19.5 2.04 3.03 25.03 0 0 0 0 24.43 760 19.5 970 970second run
JamJay
California Bound
Code:
	TIME					TIME					TIME
Wrapped in Code tags :)...
You're making between 286bhp & 291bhp based on the airflow. You're also running safe boost, around 21psi so to me this car looks very healthy. What tune are you running and with what mods?
