lukehiggs
72
Iv just had 35mm springs fitted front and rear yesterday. but doesnt seem 2 be low enough..any ideas on making it lower??
If they are brand new springs - let them settle for a couple of weeks before you make any more changes.
Try 5 people in the car for a couple of trips to settle them a bit quicker.
And don't forget - the 35mm drop is from a NEW cars ride height.
Depending how old your car is - it may have already sagged on it's springs by up to 10mm so the drop you have will only seem to be 25mm.
ye true! mine is a 57 plate. The rear seems to be higher than the front. the front has dropped nicely. needs to go another 10mm lower id say
I had them on mine the back never really came down at all tbh the front did tho left about an inch or so left to the tyre at the front. I got the back down a little bit further by releasing the pressure off the rear bushes sitting it back on the floor then tighten them back up while it's still on the floor.
