silver123
56
I have purchased a cable from alpha bid, but I can only comunicate with engine, abs and airbag controlers. Does anywhone konw where is the problem as my car has many more controlers.
Do you get a 'No response from controller !' message ? Same here. I put it down to only having the shareware version of VAG-COM.
no meaning having a shareware version. it should either comunicate with all the controlers installed in the car. I think that alpha bid cables are a bad buy.
has anywhone with other 3rd party products had more luck?
yes I get that responce, but it is not the shareware program, it seems to be the cable or the drivers.
The straing thing is also that when I run OBDII test, I get the message "the car is not OBDII compatibile..."
Same here, haven't messed around with the full version yet, although I do have it.
Used the freeware version which came with the cable, only needed to reset my airbag fault code to turn the light off on the dash.
