smiler220
rollin at 220 want more!
Oct 16, 2006
92
Bournemouth
Quick question..... If i change to a 4 bar regulator do i need to change any of the cars settings i.e use vag.com to check the air fuel mix or does the car sort this it self.
the ecu should adjust to suit it but there is no reason to do it unless your going for a revo stage 2?
if you are just clip it in place after the map has been added.
Its only one clip and a hose
When i had it rrd recently they said it would be worth while up rating to a 4 bar. I am looking at stage 2 soon just need to sort the cat and down pipe first.
