Drilled the holes 2day to fit my spoiler. Drilled thru both sections of the bootlid (As it has 2separate panels, one outside then sound deadening then another panel).
Just need to drill the inside hole to 12.5mm so i can get a socket in to tighten the nut onto it and then paint the spoiler now.
The top of the spoiler is sitting slightly higher than the top of the bootlid because if i put it level it had a 4-5mm gap between the edge of the spoiler and the boot. But it looks like it should where the holes are drilled.
