8V Throttle Body
Stace
:think: Asked a well known tuninig establishment if they could re-set my new throttle body.
They said they could but if I asked on the Cupranet someone could tell me how to do it myself for free. Anyone out there with the answer please?
Stace
Andy,
Thanks, I'm up in Cumbria near Ulverston and nearest Seat Dealer is 40+ miles away.
Local(20 miles away) VW/Audi guys v. helpfull but local guy at non franchise garage with VAG-Com doesn't seem to know his way round the software too well.
It was Awsome GTI who recommended that I do it via online help but for £30.00 at VAG dealer may be the way to go unless I can get specific help.
Almost tempted to get serial port access and software for future issues
Chris
Stace
Andy,
Thanks, will try with both bonnet and door open! (needless to say since I've bought the new throttle body the old ones been fine! I'm sure it's just waiting to take the proverbial so it's comin off tonight.)
Ceers,
Chris
jatinder
Looking for a job member
Aug 15, 2005
77
Clayhall, Essex
andythom said:
yip, open the bonnet and door, turn ignition on and listen for a high pitched hum, and a click, then all will go quiet.....sorted....
Isnt that the fuel pump priming the fuel system, to make sure theres ample pressure?
Stace
Put on new throttle body, open door and bonnet turned on ignition. No sounds so started the moto, guess what? The problem that I had is still there, exactly same symptoms! Usually dies with less than 1100 revs, sometimes idles ok, sometimes, not often kangaroos on low load and throttle, usually won't pull entirely clean till 3000 revs then sets off like a er, rabbit.
When I turn the ignition off you can actually see the butterfly kicking off it's stop intermittently for about 15 secs.
Can only think it's some kind of earthing fault(changed the main battery/earth lead and engine earth lead looks fine)
Really am confused, especially as VW agent could find no fault, in fact kangarooing started for the first time after they had had it on their analyser!
Stace
alexoakes
133
Lincoln
I had exactly the same symptoms. Replaced my throttle body with a 'recon' one off flea bay. Did the job and only cost 30 bucks i think.
My throttle body would be clicking and the linkage moving back and forth until you start the engine and then wouldn't tick over until warm and hesitated on acceleration. All sorted now though. Unfortunately i haven't got a clue what they clean/replace to make them work properly again.
Stace
V Throttle Dody
Hi,
Not sure about the port situation.
My problem turned out to be ECU not Throttle Body(despite various VAG dealers thinking it might be but unable to identify actual the fault)>
Got it repaired relatively cheaply via the internet.
Cheers,
Chris
