96 1.9 TDi low power problems
dexterbuzz
Just picked up a very cheap '96 Toledo with the 1.9 TDi engine.
It is drastically low on power under 2000 revs. After 2K it gets a move on OK, till 4000 when it's all gone again.
Is this usual or is something amiss?
I guess it's going to need an air/fuel/oil filter change and have some injector cleaner run thru it, but is there anything else that I should be looking at?
Many thanks for any opinions/advice :)
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
Sounds pretty normal. That early it will be the TDI 90 engine, 90 BHp, with a wastegate turbo. The turbo won't deliver much boost below 2k, and all diesels run out of power between 4 and 5 K.
dexterbuzz
cheers dude :)
Would that account for it revving slowly? When you rev the engine it seems to rev so slowly, like a really old agricultural diesel. Is this usual for this car?
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
Not sure what you mean by revving slowly. You can't get more power out of a diesel by increasing the revs like you can a petrol engine, the combustion process is different and all that happens is you get a lot of smoke out of the back, and lower power. Best power in the TDI 90 is between 2000 and 4000 rpm.
dexterbuzz
I've had/got other diesel cars and you normally get a fairly quick response when you press the throttle, i.e. press the throttle and the engine will rev.
With this, it's like press the throttle and there's a distinct lag before the engine will rev and the revs rise very slowly.
I'll have to go find someone that's got a similar one so I can compare!
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
OK, well that's not right. Turbo wastegate not closing or EGR not closing completely would be my guesses? Doesn't sound like a boost leak, that would get worse as revs rise.
