Olly20VT
1,233
Stroud Glos ,England
Were in the car is this and how much are they and dose anyone know the part number?
My A/C has stoped working and the A/C flashes on the center consol even at 10 deg's out side temp.
I ran VAG-COM and it mentiond the sensor but i forgot to save the fault, i will post up what it said later when i have time to run VAG-COM again.Any info would be good.
P.S here is the VAG-COM reading....
Control Module Part Number: 6K0 959 291
Component and/or Version: AUTOCLIMA-220 X03.03
Software Coding:
Work Shop Code:
1 Fault Found:
00792 - A/C Pressure Switch (F129)
03-00 - No Signal
Hope this hlps some one to help me.
You may have a leak. Get it checked. I replaced my pressure switch, but dont have a part number, i think it was around £30.
iirc it fits in the pipes just before they dissapear inside the car to the heater by the bulkhead block bit
no signal ? - check the connections/wires are ok first but may be down to no gas i.e a leak :)
I've taken the black cap off the front pipe and poked a pen down, i did get a wooossshhh of gas, i only did it for a split sec just to check, so that shows there is some gas in there, still duno how much.
Is there a way I can check the gas level properly?
Nope you cannot check the gas level unless you have the proper equipment.
Be carefull you don't get the "gas" on you skin as it will burn you.
its on the passenger side where the pipes go through the bulkhead. It has a valve under it, so it can be unscrewed without leaking gas out. Iam sure it has a 3 pin plug on it, but cant be certain.
Found this......
Possible Symptoms
A/C System not working
Possible Causes
A/C System Malfunctions
Over or insufficiently charged
Refrigerant System blockage
Insufficient Air Flow to Condensor and/or Engine Radiator
Wiring to/from A/C Pressure Switch (F129) faulty
Possible Solutions
Check A/C System for Malfunctions
Check Wiring to/from A/C Pressure Switch (F129)
Check A/C Pressure Switch (F129)
Throught it might help anyone else witht the same problem, i'm going to have a look at it soon, i'll post up my findings.
i got the gas checked and it was empty so had it refilled and after 2 weeks it was empty again, so i had it filled with dye and it's just run out so i'm booked in again so they can check were the leek is.
So in short i'v got a leak.
