Bigjohn84
Intagram / johnyoung84
May 5, 2015
2,329
List of fault codes, the faults and how to fix the faults
http://wiki.ross-tech.com/wiki/index.php/Category:Fault_Codes
Changing rear pads and discs
http://www.seatcupra.net/forums/showthread.php?t=225698
Spark Plug Gap | Spark Plug Gap Chart
http://www.briskusa.com/spark_plug_gap_spark_plug_gap_chart
How to change radiator
http://www.vwforum.com/forums/f15/mk4-radiator-replacement-diy-51597/
http://www.pelicanparts.com/techart...nt/18-WATER-Radiator_and_Hose_Replacement.htm
https://youtu.be/m2IvmVkszWU
Video for fitting gearbox shim and cap
http://forums.vwvortex.com/showthre...tch-disengagement-issues-mainshaft-axial-play
Parts Number Catalogue, click on make of car and register to view
http://www.vagcat.com/epc/
How to wire a Boost Guage Up
http://www.seatcupra.net/forums/showthread.php?t=72432&highlight=oil+pressure+guide
How to fix those leaky doors, if you have wet carpets this is the guide for you
http://dubsteve68.blogspot.co.uk/2011/05/seat-leon-leaky-door-seals-repair-guide.html
Ultimate SAI/N249/PCV/EVAP Delete
http://forums.vwvortex.com/showthread.php?4893472-DIY-Ultimate-SAI-N249-PCV-EVAP-Delete
Seat Leon owners manual
http://lee69.co.uk/Car stuff/Leon/Seat Leon 1M Manual.pdf
How to clean your throttle body
http://www.briskoda.net/forums/topic/129943-cleaning-throttle-body-18t-engine/
How to fit an oil catch can
http://uk-mkivs.net/topic/17685-18t-pcv-simplification-and-catch-can-installation/
http://www.audi-sport.net/xf/thread...catch-can-and-simplify-the-pcv-system.118021/
How to fit rear axle bushes
http://uk-mkivs.net/topic/100211-how-to-rear-beam-axle-bushes-cupra-r-bushes/
How to remove the trim panel on the lower part of a SEAT Leon Dash
http://www.icecavern.com/howtos/leonlowerdashtrim/main.php
How to fit a turbo inlet pipe or your oversized sfs tip
http://www.ottawa-vdubbing.com/forums/phpBB3/viewtopic.php?f=22&t=8651
How to change ur K03 Turbo to a K03s
http://uk-mkivs.net/topic/17385-k03-k03s-turbo-diy-how-to-fitting-guide-mk4-golf/
I'll add more as I go along with my own car, hope these links help you with what you need to do.
