stu1986
102
redditch
I've got 2 problems that are starting to anoy me
1st every now and then when I turn the steering wheel the horn goes off at first this was funny but when turning in busy car parks the horn going off gets a lot of looks and people thinking I know them
2nd my rear wiper and rear washer both are not working the fuses are fine but the motor makes no noise at all the fronts work fine just the rear
Any help to these stupid problems would be brilliant
Stu
The 1st one is hilarious but both could be dodgy wiring. The 1st sounds like two wire connecting but the wiper one, can you check to see if power is actually getting to the motor?
1st sounds like dodgy contact possible a pinched cable in the steering assembly or the slip ring is failing
The 2nd sounds like the wiper stalk contacts has failed best bet would be to check the MVB's while operating the switch and see what the results are.
