weemzer
upside down not good!!!!!
Jun 30, 2006
182
Perthshire
I was just gettin my car ready to head off to crail on sunday when my abs and traction control lights came on!!! had a code reader on it tonight and got p0116 and p0411 (engine coolant temp circuit range/performance problem & secondary air injection system incorrect flow) can any of you lads shed some light on this? i'm hoping the secondary air problem is just the vacuum pipe off the pump but i'm confused about the coolant temp issue? do u reckon it's just the level sensor in the header tank that's ****ed up?
plus i can't see how this would send up tc and abs lights????
any help would be much appreciated!!!
Coolant temp sensor is knacked mate, very common amongst VAG cars.
As for secondary air fault, just erase it and see if it returns before doing anything.
