DaNnY_LaD
Big Turbo Leon Cupra R
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Right i got a Abs & tcs light a few weeks ago and it was off and on...
Now ive fitted the drivers side Abs sensor the lights on all the time....Ive check all the wiring and its spot on and the Fuses are fine too...
This is the code i keep getting and it dosnt go away:00285 - ABS Wheel Speed Sensor Front Right (G45):
Copied from ross tech:
00285 - ABS Wheel Speed Sensor Front Right (G45): Signal Outside Specifications
00285 - ABS Wheel Speed Sensor Front Right (G45): Electrical Fault in Circuit
Possible Causes
Open Circuit in Wiring from/to ABS Wheel Speed Sensor Front Right (G45)
ABS Wheel Speed Sensor Front Right (G45) faulty
Possible Solutions
Check Wiring from/to ABS Wheel Speed Sensor Front Right (G45)
Check ABS Wheel Speed Sensor Front Right (G45)
00285 - ABS Wheel Speed Sensor Front Right (G45): Mechanical Malfunction
Possible Causes
Excessive Air Gap between ABS Wheel Speed Sensor Front Right (G45) and Rotor
Short Circuit in Wiring from/to ABS Wheel Speed Sensor Front Right (G45)
Possible Solutions
Check ABS Wheel Speed Sensor Front Right (G45) Installation
Retrieved from "http://wiki.ross-tech.com/index.php/00285"
I'm getting worried...
I've been having the same problem for the last couple of weeks.
only code I am getting is the 0285, due to my wiring. I redid the wires and it was fine for a bit now it comes on all the time.
I now pulled out the fuse waiting for time to solve this.
Should you find out more keep me updated please
ive just had an abs fault come up, but mines front left, outside normal parameters, must be the season for it lol
you said you checked all the wiring so i was wondering what u did to make sure it was ok
you can test the sensor itself by measuring the resistance and the wires i usually test both resistance and continuity if possible
:ban:
Flapper do i test it with a digital Multimeter?
I just done a visusal Check on the wires in the arch..
