and me..
This just happened to me - about 2 weeks AFTER getting the ABS module replaced. Any update on yours?
Hi
No I've not sorted my problem yet, still got abs light on and handbrake light flashing with 3 beeps on startup.
I will get it checked when I have some time, driving without abs and traction control seems fine, just the lights in the dash are annoying, lol,
I guess it's either the wiring to abs ecu or the abs ecu itself needs replacing
Hope you get it sorted
I've literally just had the ABS ECU unit replaced! :-(
I'll ask the garage to check the wiring....
Thanks anyway
Oh blimey, was it new unit or second hand, did the garage recode the replacement after fitting
It was my original unit - but repaired and modified so if sensor goes again it can be replaced without changing the whole unit.
I decided that was the best option since these units go every 3-4 years and I didn't want to shell out £1200 + again!!
Garage was a SEAT specialist and came highly recommended on here. Have e-mailed them but no reply yet so I'll give them a ring this morning to see what they have to say.
Finally got it sorted today, got a second hand abs pump and ecu fitted, turns out it was the abs ecu, no more flashing lights on dash and abs/ traction control back.
Total cost £180 including fitting
