ian_cupra
hi guys,
anyone had these on there TDI's?? car is a 100pd sport rider.
18263 - powertrain data bus : software version monitoring
p1855 - 35-10 - - intermittent
18047 - accelerator position sensor 1/2 (g79/g185) : implausible signal
p1639 - 35-10 - - - intermittent
cheers guys
Out of the many many vag-com logs I have over the years, I have never had those mate sorry :(
You might be best either moving this to the VAG-COM section, or the TDi section for better results
its under warrenty anyway, so seat looking at it, just wondered if anyone had it before thats all
sorry to bring tolife an old thread, but after removing | cleaning | attaching egr over weekend i had the EML comeon with that same issue:
18263 - Powertrain Data Bus: Software Version Monitoring
P1855 - 35-00 - -
a google finds a few threads but none to explain. I also have a second which was:
19586 - Shareware Version. To Decode all DTCs
P3130 - 35-10 - Please Register/Activate - Intermittent
Which i think is safe to ignore...
Did you get an answer from seat ian cupra?
car drives fine, but driving to gatwick tonight and a little worried
the problem was the throttle pedal, but i'm not sure what it (18263 - powertrain data bus : software version monitoring) means, i just know the other one i had was for the throttle pedal.
cheers ian.
not sure if i should be worried or not though.
wondering if it is re-learning driving style as it were as cleared the DTC and didn't come back on after drive to work.
will monitor it and see what goes.
