Jonzy
Advice - Logs attached - Updated results!
Did 2 tonight logging 003,020 & 115 - running esso 97sul .. heres the results
1st one is a 3rd gear run
Clicky
2nd is a 4th gear run
Clicky
Advice welcomed, I know the MAF is reading low but im concerned about the CF stablisation being high... poss due to the MAF? :)
Picked up a new maf this morning (ecp £60), will relog it again tonite and fingers crossed it should solve the problem :)
Cheers fella, hope it works otherwise im in the same situation as you.... same error code!
MAF is just over 1/2 what it should be reading.. so plenty to be fixed by a working one being in there.
Just fitted it in the carpark, took it for a drive and it feels slower, much slower. Will do a tba tonight and then re-log it.
Is the aqx engine dbw?
Didnt know AQX came in the Ibiza. Thought it was only AYP.
Also, youre block 020 logs, the CF's values are very high. This shows a high amount of retard. Yes? No?
I passed judgement too early on the new maf, its transformed the car. Maf logs at midnight when the 'private airfield' is queit ;)
Im hoping that the CF's should drop now... only vagcom can tell.
Took it for a little run and logged this
Clicky
CF's are 0's and peaked 136g/s @ 100% load
Will get a better run tonight for a real result, but its looking good :D :D :D :D
Cant remeber, possibly 2nd - just backed it off in the traffic and pinned it :cry: :D
Just got back from another logging session - looks like the new maf has solved the
problem
Clicky
4th gear run
Comments welcome :)
yep, think the speed was indicating 125-30. Woulda pushed further but didnt see the need and was running out of road.
