Air Con Help ?
pickie
222
hi all my air con gave up the ghost today :( the little AC light on the screen shows but no cold air, just the normal outside air temp :(
1) could this be due to it running out of coolent gas ??? as the car is now 4 years old and never be charged ??
2) is it fooked ?
cheers
pickie
alexoakes
133
Lincoln
If it's anything like mine check the 30a fuse on the right side of the fuse box on top of your battery. Won't be blown but I get dry connections there quite often. Clean and re-seat the fuse, hopefully that will sort it. You will probably find it is stuck in quite stiff. Just give it a good yank with some pliers.:D
pickie
222
ok if the fuse dont help my air con im going to go and get a diy regas kit
?? where is the air con refill nipple on the car Ibiza MK3 ??????
ianbvw
104
norfolk
get it regased properly its only about £50 sqiud plus the old gas has got to be disposed of properly!
o and the gas is dangerous
Addo
Rick-24 said:
could be your outside temp sensor, have u read wat temp its showing latey?
I've noticed that on mine recently e.g. 3pm yesterday it was showing 12 degree when it was showing 29degree in a car next to me. Where is the sensor located any ideas.
JimyFloyd
234
Under the passenger wing mirror. You'll see a little black thing sticking out, take the back plate off the wing mirror andput a new one in
£20 or so from seat
