Dodson
Extreme Blue
Feb 9, 2005
610
Redcar
Was on my way to work this morning (3 hour drive) and i was thinking 'how the hell am i gonna get the money for a FMIC' when i ha a thought...
Is it possible to get a cold air feed onto the SMIC on the LC (facelift) and is it beneficial or another stuck in motorway traffic bored useless idea?
Is that the only thing possible?
I also have the Carbonio which is probably around the same position the other side, the only thing is i like the look of the fogs.....although they never get used anyway!!
there will be benefits, but none of them will actually make the same difference as the FMIC would
Why not try it and see what you think? Remove the fog lights, remove the plastic shrouding and get a decent air feed in there too... all of which will cost you around £20 and a lazy Sunday afternoons work.
Live with it, see what benefits it brings (if any) and take it from there. If you're happy, problem solved! If not, put it back to the way it was and you're not really any worse off.
Sounds like a plan RobM...just need the car back nowthen, as there aint much point trying it on my courtesy Corsa!
cut the arch liner and fit some louvres or mesh.standard on other VAG motors with a smic
I was over on briskoda.net the other day and i saw someone had done this mod, is it worthwhile then?
The TT has vents in the arch liner as standard and as far as I know it's not a huge or particularly expensive job to get these and cut them up to fit the Leon. They don't fit straight in obviously, but you can buy the TT arch liner and cut the vent out... then cut up your liner and plastic weld the vent in.
Or, go ghetto with it and pop down to B&Q and get yourself an extractor fan vent and paint it black and fit that instead!
Yeah that's another option.... but I think I'd prefer a proper vent to be honest, just seems tidier job?
