my advice, plan what power you will be going to, you may find you need a bigger tip, maf, and filter for the power you are looking for, which means you will be replacing it twice, dont make the mistake i did, bought everything once, changed the setup and have to buy everything again - but bigger
p.s if money is no object, i would go either jabbasport filter or dynatwist, have spoken to alot of people and seen them running the dynatwist with no problems, i run the jabbbasportand cannot fault it, people say its expensive, worth it imo if your pulling 167g's from a k03 ;)
from other discussions on here i dont think there is as big a gap between the ko3 and S variants as people are sometimes led to believe, maybe 10-15 brake horsepower, turn that into g/s and its maybe only 8-12g/s , a decent exhaust and intake would bridge that gap.
HA, 45 bhp & 35lbf-ft in my case. ;)
If you want to here the dv and induction sound buy an open cone. Bill sells them.:)
I have one single cone ibiza cupra induction kit in stock...
£60 to clear inc vat plus postage
make your own shielding to go with it and bonza, woosh tastic :D
