Jazzy_Cupra
Hi guys
yet again another issue
MOT FINALLY SORTED BY THE WAY... Thanks for all the advice
I had a diog done a couple of weeks ago as the car was lagging in power it accelerates then kind of stops then starts and stops and so forth so took for diog and was advised it was the common AIR MASS that was gone.
I replaced this yesterday done as i was advised I took the battery off replaced the AIR MASS and then reconnected battery, Took car for a drive but still exactly same problem. Have been told i need to get ECU reset has anyone else had this problem?
Also is this the case that i need to get the ECU RESET after replacing AIR MASS. Any advice would be much appreciated as this is really starting to get to me real bad.
Thanks in advance
Thanks in advance
