Air Mass Problems
Jazzy_Cupra
Hi guys
yet again another issue
MOT FINALLY SORTED BY THE WAY... Thanks for all the advice
I had a diog done a couple of weeks ago as the car was lagging in power it accelerates then kind of stops then starts and stops and so forth so took for diog and was advised it was the common AIR MASS that was gone.
I replaced this yesterday done as i was advised I took the battery off replaced the AIR MASS and then reconnected battery, Took car for a drive but still exactly same problem. Have been told i need to get ECU reset has anyone else had this problem?
Also is this the case that i need to get the ECU RESET after replacing AIR MASS. Any advice would be much appreciated as this is really starting to get to me real bad.
Thanks in advance
Jazzy_Cupra
took car back in for a diog and get ecu reset problem still there. apparently now ive had code PO 003 or it could have been P0 03 APPARENTLY A MULTIPLE MISSFIRE. So now i believe i need to get 4 new coil packs :s cars are really getting on my nerves...
Jazzy_Cupra
it come up on diog as multiple miss-fire cars on a 2002 plate so unfortunately not covered under warranty. i just ordered 4 coil packs today just hope this cures the problem.
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
Just been through this, had to replace the 3rd coil pack today and and with a new set of spark plugs!
Cant belive the denso plugs just blew! Only lasted around 2months! Oh well
Yeh the missfire is caused by your coil packs
Jazzy_Cupra
Put 4 new coil packs on guys and cars sorted so god knows how many were gone but thank god its all sorted.
so after all them diagnostics and air mass meter run around turned out to be the coil packs.
Big_daddy
Oct 20, 2006
3,930
Brummy
Did the coil packs leave a fault code?
Jazzy_Cupra
God knows probably going to have to go and get it reset arnt i. Not sure but theres no lights on the dash etc.
chriswilks
Astra CDTi track car
Jun 3, 2007
330
warrington cheshire
what trouble you have with your mot "jazzy cupra" ???(that does sound slightly camp!)mines just failed on emissions but been doing similar things.its been in the garage for a few days so 2moro i should know whats wrong.
Big_daddy
Oct 20, 2006
3,930
Brummy
Well the funny thing is mines did record a fault! The mechanic spotted the symptons staright way and checked each coil pack 1 by 1. till he found 3rd one dead!
