Airbag light on fault code 00588
jamie8954
Diesel FTMFW
Jun 29, 2008
553
UK
00588 - Airbag Igniter; Driver Side (N95)
00588 - Airbag Igniter; Driver Side (N95): Resistance too Low
00588 - Airbag Igniter; Driver Side (N95): Resistance too High
00588 - Airbag igniter driver's side (N95): Short to positive
Possible Symptoms
* Airbag Warning Light active
Possible Causes
* Wiring from/to Airbag Igniter Driver Side (N95) faulty
* Coil Spring with Slip Ring (F138) faulty
* Airbag Igniter Driver Side (N95) faulty
Possible Solutions
* Check Wiring from/to Airbag Igniter Driver Side (N95)
* Check Coil Spring with Slip Ring (F138)
* Check Airbag Igniter Driver Side (N95)
Special Notes
* When "Short to positive" is found, DO NOT CLEAR THE DTC. This can cause the airbag to deploy. See repair manual for more information.
Whats the airbag ignitor ?? will it need replacing i was sat in ca it made beep noise from dash and light come on , cleared fault code light went off then come straight back on again anybody help please ?
Bondiblu
Enthusiast
Mar 18, 2007
1,648
Cheshire
The ignitor is the part that deploys the airbag, will it need replacing?? I don't know, the fault needs to be found, may be a broken wire or something. I would take it to a professional for further diagnosis
