Airbag light
Guinness
Finally got the BMW
Nov 29, 2006
4,421
Newcastle
Well as title say my airbag light came on today and well Im rather shitting it tbh lol. Irecently had the glove box apart moving the wire from the glove box light so Im thinking it could be that any ideas?
rashcupra
MV AGUSTA & 1.8T DUB MK4
Oct 15, 2006
6,517
crawley
you'l need to get it turned out via a diagnostics kit that will also tell you where the fault is that caused the light to come on! would worry to much mate! are you playing around near the passenfer airbag wires :think:
Jul 17, 2004
1,829
West Lothian
Or it could just be a faulty sensor. I had that happen with my old car on the first day. Except Uncle Arnold made me wait for 2 weeks while they sourced a replacement airbag for it, before realising the sensor was the problem and not the bag itself.
EdButler
713
Sheffield
Just unplugging the connector behind the glove box will switch the light on... Its simply a 'fault' you must erase from VAG COM
PLEASE NOTE! Your airbags and Pretensiones will not work when the airbag light is on, if i remember correctly. So rather sooner than later!
Boom^
¿Puede hablar Español?
Guinness, shame youre a bit far away but if youre ever in the doncaster area i can happily switch off your airbag light for you with vagcom on my laptop. I had the same problem and it was caused by my battery going flat. So just cleared fault code in vag com and viola it went off... its if it comes back on again when theres a problem. Dont let a stealer charge you silly money though, its literally a 2 minute job to clear the fault code.
rashcupra
Oct 15, 2006
6,517
crawley
it is dead easy id do it for you too ;). doubt he would have unplugged a yellow plug for the airbag if he was re routing some wires he put in :shrug:
