My alarm is going of for no reason.... Can I change the values via Vag-com so it just dead locks the car, and stops the silly beeep beeep beeep from the horn...
Found that the middle seat passenger side had broken the moulding around the inner sensor..... So it would get a naff reading and hence beeeeeeeeeeep beeeeeeeeeeeeeep .... funny also around 2am.....
try checking u dont have a partly seized door lock/ boot lock have had problems with these before, also check wiring between doors, also check the ecu for damp/ water damage.
hope that helps
