Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
must feel bit quicker the car now yes?
Looking good Chris, going to sort my pancake after Christmas. I love the rest of the Allard kit I have. Do you find that boost is held much longer too mate? My car actually revs now lol. The sound is mint too, like a low burble at idle but a roar under load.
Chris,
This is just an observations but my gut is telling me that you have angle the turbo outlet pipe wrongly (i may be wrong). It will rub as I found out when I found a 50p size hole in it months later. You can angle the pipe will away from the driveshaft but not sure with the allard pipe as I cant make out the angle?
Can you push your pancake pipe more into the turbo outlet to move it away from the arb?
Depends what you are trying to achieve with the claybar. They range from mild to aggressive.p.s jonjay - do you have any recommendations for clay bars/sprays?
Well I have decided I am going to fabricate this pipe out of alloy and make a more direct route if possible...problem sorted.
I got very capable company that can practically make anything to specification...Also Slick (one of me best mates) is a CAD technician so he can design it. HOWEVER there is no need for designing anything as I got a spare SFS one so they just need to replicate and make improvements.Mmm there are two lugs on the actually turbo, where the lugs for the connector goes, once over tight and clamped down, the jubilee should be able to get over the lugs, mmm who would make one for you mate, would you still use a conenctor into the turbo?
