Alpine iDA-X100 Purchaced.
Stuart83
290
Tamworth, Midlands
Yeah, if you want Imprint loaded I think you need a seperate box with the IDA-X100. If you get that installed, go to your local dealer and they'll "imprint" your car. Seen a few of them being done in the workshop here (I work for Alpine), and they sound awesome when theyre done.
Basically they sit a microphone in different positions in the car and calibrate the sound system. According to the tech dept it makes a huuuuuge difference, they swear by it.
dmmsta
Sold car - bought bike
Feb 10, 2007
787
Maidstone - Kent
I've got the extra bits of kit, Imprint system, and the microphone & software, the problem i'm having is finding out how to hook the system up using the internal amp on the headunit.
Anychance you can ask the tech bods if it has to run thru external amps, or if it is indeed possible to use the internal amp please :clap:
Mattsd
legend headunit had mine for a few months now, had the 200 but moved upto the 100 because i wanted a red illumination to match the rest of the interior lights. Only small problem, what form is the aux in, i got some RCA leads but they only seem to be for speakers F, R and sub. Any help????????????
matt
dmmsta
Feb 10, 2007
787
Maidstone - Kent
matt
When you say AUX in, what are you trying to connect?
Mattsd
am after a cable to plug into headphone jacks on other MP3 players other than ipods,
gus
476
dmmsta yeah thats all u need for u to have the imprint, mate i work at alpine and once you have heard the difference you will LOVE it.
just make sure you have decent upgraded speakers to really appreciate the imprint.
dmmsta
Feb 10, 2007
787
Maidstone - Kent
I was sure I had the right kit, just totally purplexed as to how to connect the PXA-H100 back to the iDA-X100, but I think I've just found out...
Bad case of RTFM on my part...:doh:
Me thinks a weekend of pulling the car apart again is in order...
Still running standard speakers at the mo, but that will change, and then I'll run the Imprint setup again just to make sure!
gus
476
the with the pxa-h100 and ktx-h100 is around £160 and then you will have SUPERIOR SOUND than everyone else hahahahaha :))
ill be doing this very soon
dmmsta
Feb 10, 2007
787
Maidstone - Kent
OK, here comes the stupidity...
I've lost the CD with the Imprint Sound Manager on...
I've looked on the web and couldn't find it available for download...
Anyone point me in the right direction, or have a copy available?
gus
476
dmmsta ae you talking about the imprint software??? and mattsd call alpine on 0845 313 1660 the techinal peeps will hook you up!!!!!!
dmmsta
Feb 10, 2007
787
Maidstone - Kent
Yeah, the "Imprint Sound Manager" that comes with the KTX-H100, I have a feeling my 2yr old fed it to the toaster... :cry:
gus
476
the part ur looking for is the ktx-100eq????is that correct? if so ill see if i got one around if u want????
dmmsta
Feb 10, 2007
787
Maidstone - Kent
It's the KTX-H100 (CLICKY)
Basically the H100 is just the software, microphone, and a couple of other cables. The 100EQ looks like its another bit of hardware as well??
Not sure if the software is the same tho...?
Sorry to be such a pain...really must learn to hide CD's from the little man's hands...
gus
476
what u mean u dont know what size it is???? what does that mean?? do u just need the cd with the software on it?
halftone
148
Dudley, West Midlands
Anyone got this working with steering wheel controls ?
Also, its a right bugger to actually fit in place, there seems to be a little ridge in the ibiza dash, that stops the cage being pushed into place. Think i might have to move it around and have the hu at the bottom, tray at the top
dmmsta
Feb 10, 2007
787
Maidstone - Kent
Sorry meant size of the data, incase it was easier to send electronically...
Yes need the software, in whichever format is easier for you...
Cheers!!
