white_vts_boy
79
Just purchased a forge 007p on eBay I've just purchased my car and it is completely standard! Today I had the bonnet up and thought I'd have a look how easy it was to get to the standard recirculate valve to fit my forge when it comes and guess what I saw! Forge 007p! It's so quiet! Are they meant to be so quiet? Anyways if anyone wants one of these il be putting it in the forsale section when it comes
I have a air filter, makes abit of noise but nothing to scream about, is there a better valve to get?
You can get a dump valve but from what I can get her this causes a lot of problems with the system and puta engine management light on
You need to get an open induction kit as opposed to replacement panel filter. Something like the Neuspeed P-Flow was always a common upgrade and definitely gives a good "whoosh" noise.
If your after the noise then fit a decent Cone filter jetex is popular but whatever u do don't fit a vta valve thus will lead to issues as it's effectively causing a boost leak, so a good cone filter and u will have some noise as the valve works
Sent from my C6603 using Tapatalk
