Josh has the stage 1 AM04 and AM Manifold. At the time of mapping it made 260bhp and 309lbft at Jabba.
Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
definately similar to E05 outputs too then
inlet veins look seriously similar too.
Bad because E05 were not reliable! But as said earlier, Mike has ran it for 2yrs + with no problems, I wouldnt worry about it
so basically its just a E05 then with A&M stamped on the side? how much can a new E05 be brought for from a dealer?
Kev kicked the crap out of his for 2yrs (but did fail in the end)
I wouldn't say a test bed of 1 proves it's reliability (but hopefully it'll be fine)
I personally would like to achieve a reliable 260-270 which is yet another 40bhp increase over it's current set up. Is the AM unit a better option than the Eliminators?
Ian
Th
Question for mike/addo>> Is the AM04 a new unit or built using used parts and carries what warranty
they turbo is constructed using a mix of parts i.e. k03s/k04 parts are new and sometimes refurbed i.e. from k03's to mutilate.... in actuator on david's case that was reused as sports actuator was requested.
All turbos are balanced checked, any refurbed parts re-checked. but core is new unless otherwise stated as we can do used options. housings etc will show signs of machining/modification etc....
Bill do you know what warranties turbo suppliers such as eurospec offer for their turbos when sold?? i.e. did E05 boys get full refund for their turbo popping ? or yourself with your IHI's going?
and thats becuase a turbo can go for a million reasons and alot of them is down to human error and/or excessive abuse
