Happy with the results i get from the megs stuff. Only have to do it once a month, unlike when i used auto glym, nearly every week.
Ive noticed that sometimes it comes up purple in the sun, like theres a slight flip in the paint, looks very trick for a standard colour
Added some new touches today
Got a badgeless fk grille for the bargain price of £20, fitted it straight away
New alpine headunit with bluetooth and ipod
Also fitted a glovebox light and an holder for the ipod in the glovebox
And an armster armrest off ebay
Looking good,iv always used auto glym an have just got the high defanition wax,might change 2 maguiers because yours dose look sweet!
The picture with the grille was taken 3 weeks after I polished it, and it still looked shiny, only needs doing once a month now, just gets washed every week!
Got a sunglasses holder that goes in the space of the grab handle, and some new hid bulbs (got some 6k, instead of 10k), and then saving up for the windows to be tinted (light smoke all around), lowered 40mm, cupra bumpers then anything else I see, Stuck for ideas then :blink:
Cupra headlining kit, dash bling maybe? Gearknob/air vent surrounds? Nice exhaust? Panel fiter? :D
Already got a panel filter in, got a pipercross one. Seen some rings that go around the vents that I may get and some that go in front and behind the ger stick. Unsure about an exhaust as i cant see any for the 1.4 16v, but would like a nice oval one. What does the cupra headlining look like?
Also the armrest does get in the way of the handbrake when its down, all i do is put my arm around it and pull it up, it can be tilted back and put out of the way. The top slides forward and back, also it can be adjusted for height slightly with a dial underneath.
Couldnt be bothered with messing around with a headlining, too much hard work.
Wouldnt the diesel exhausts be a different bore, or are they all the same size?
I'd imagine probably bigger. I think the tdi's are 2.5 inch bore. But like I say - the diesel system has only one silencer whereas the petrols have two. So it would make it louder and still be genuine SEAT parts. :)
Thanks for the comments so far
Yet more spending on the beeza over the last month
Firstly had it serviced at a local independent vag garage, JVW in Haydock, top bloke
Also added a new richbrook aeriel as some theiving little g1t nicked the standard one (Even though i would like to kick their teeth in, I also would like to shake their hand for getting it off and not damaging the car)
Also got a set of wind deflectors off ebay
Next up is to sort the little niggles out, mainly the anti roll bar knocking, and the faulty lambda sensor, then in for the windows to be tinted (light smoke all around)
Got bored when i got in from work, Didn't like how long the aeriel was so cut it down a bit. Heres how it ended up
Looks good but it does sod all for the signal for the radio :rolleyes:
