Anyone Fitted Oil Temp Gauge
B3NPM_Cupra
Money = Power!
Dec 9, 2006
262
Tamworth (West Mids)
Will need a temp sender fitting, should come with the gauge. This is the best place. thers a blanking plug already there.
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Although there is a blanking plug there, most of the time there seized in and quite hard to get to, I found it alot easier and less time consuming spending the £20 and getting the sump plug from demon tweeks with the middle tapped out for the sensor. Was nice and easy as i was doing a oil change at the same time. Apprently much more accurate aswell.
David.
Nov 2, 2004
9,335
South Wales
I use that position for oil pressure. Sump plug for oil temp for me although its probably not the most accurate position to take a temp reading.
