dav150n
71
durham
as the heading states, do they have one? (can't remember if mine did).:confused:.
if so does anybody know how to change it? (as mine must be blown).
Some MK4's do have one and some don't. The bulb for the fag lighter also illuminates the ashtray. The way to tell is to stick your finger into the fag lighter socket, try to hook your finger and pull up at the same. The lighter socket will pull up out of it's mounting hole and you will see if it has a bulb atached to the side of it.
If it has a bulb then you can replace it, if it doesn't have a bulb you can buy a MK3 Ibiza fag lighter as all of these are illuminated even on the poverty spec ones in the scrap yard. The MK3 fag lighter is a direct replacement and you can wire up the bulb to the traction control illumination wiring if you have it or anywhere you fancy that is ignition switched.
Good luck.
Here is a pic of mine with a MK3 lighter fitted >>>>>>
your a star. i'll give it a bash tonight and let ya know what happens. a could of sworn it did have one when a bought it.
tried it and nearly pulled me :censored: thumb off!!!! al keep trying though. any more ideas anyone?
or is that the only way? it must have one, it already had a boot light though, put a glovebox one in meself:p
I don't have an ashtray light, boot light or glovebox light :( I've got the parts to fit boot and glovebox one but never got round to it.
I have a ashtray light but no boot or glovebox light, totally useless for me as i dont smoke and i'm always chucking stuff in and out of my boot [:@]
