Audi --> SEAT adaptors...?
B19_TSH
155
W. Yorks
I'm bidding on some wheels on Ebay and just wondering what adaptors i'll need? Here are the details of the wheels:
Rim Information Tyre Information
Metal Type: Aluminium Tyre Type: All-Weather
Rim Width: 8J Tyre Width: 225
Rim Diameter: 17 inches Aspect Ratio: 55
Offset: 56
Number of Studs: 5
Stud Diameter: 112 Tyre Manufacturer: Michelin
Rim Manufacturer: Speedline
Rim Structure: One Piece
My car is an (02) Ibiza Cupra
Cheers, Tom
JKing
Cupra-R
Aug 9, 2003
598
Mansfield, Notts
photobucket.com
didn't realise they were available but fair play if they are. I guess they bolt to the hub and must be at least 15mm thick so you wouldn't require spacers for the rear but not sure how you'd get on with the fronts. Actually thinking about it, the guy on here with the yellow cupra that was in the bodyshop recently. Had a full respray and various parts smooth, I'm sure he was running 5 stud Porsche rims
andyj
There's no F in Quality..
sorry guys, but you can't buy adaptors to go from 4x100 (Ibiza) to 5x112 (Audi) as one of the bolt holes on each pattern overlap.
However, you can get 5x100 -> 5x112 adaptors, so if you really wanted to you could change all your hubs etc to Mk3 Golf ones and then use the adaptors to fit the wheels.... alot of work though.
andyj
As you can see from this quick sketch, the top hole of the 5x112 pattern, overlaps the top hole of the 4x100 pattern.
and rotated 45 degrees:
The left hand hole now overlap......
Which ever position you have the 5x112 pattern, you will always get an overlap of holes.
This means you cannot get a sufficient securing point on the 5th hole :(
RickC
BUILT NOT BOUGHT
Dec 23, 2004
1,621
Lincoln
i have a brand new set of wheel adapters made up to convert 4 x 100 to 5 x 100 if anyones interested? they cost nearly 500 quid custom made jobbies.
