stolen
71
Hello people,
I have posted this question in the q&a but didn't really get an answer - I started the leon about two weeks ago and the doors locked automatically - ok - unlocked them and started driving and it happened again a few minutes later - from the previous post answers, i know there is an autolock feature in the car but it has never been enabled - since then it happens sometimes at different speeds and sometimes not at all - weird - also, when it does occur, the car dooors do not open when i take the key out of the ignition - anyway, has anyone had experience of this happening to them? - or better still a solution to the problem?
Any help appreciated,
David
it's possible it was enabled by the dealer / factory before you knew it...
and that the unit is faulty. it's easy to turn off if you have vag-com (or know someone local who's handy with it)
thanks for the reply mork - i have ordered a cable from gendan and will have it shortly - will the shareware version of vag-com allow me to do this? - if so, do you know how? - thanks again - david
I activated this on my Tolly with vagcom. locks above 10mph and unlocks when key removed
will see tonight where the little section is so you can check
