B&M short shift kit
turboholic
CupraPower
Mar 4, 2010
355
Bristol/Bath/Frome
Get an ebay copy there are identical and a fraction of the price. And yes you will need a new gearknob aswell as it is lift reverse.
You will need to remove the heatshield to get the to the shiftbox out as it comes out from underneath. Most people remove the dp to get it off (although 1 guy managed to do it without)
Whilst your at it you could topmount the shiftbox like I have which looks pretty cool.
where did you make the hole for the cables to go through the firewall?? have you got any pics of it from inside?? and also what size is the hole??
doing mine tomorrow :)
Jul 4, 2010
2,170
Cambs
Nope I used 4 m10 allen bolts and nuts on the underside.. made spacers to fill up the larger holes in the box.. probably get away with big washers though
turboholic
CupraPower
Mar 4, 2010
355
Bristol/Bath/Frome
Did mine today. Very happy with the result!! Removing the shifter box was a right pain in the ass but I managed to remove it without removing the downpipe........
The hole I made for the cables to run through the firewall provides a nice sound of the turbo spooling and the dump valve :D
murray-cupra
65
Aberdeen
ok guys thinking about fitting one of these to my cupra. i dont have mad skills when it comes to working on cars so could someone tell me how difficult it is to fit on a scale of 1 to "oh f@#k"
cheers!
May 25, 2008
2,400
cambs
For everyone's info these can be fitted from above with no need to touch the exhaust or heat shield just need abit of patience and a telescopic magnet !
As I've just fitted mine
Apr 15, 2009
2,189
Midlands
I fitted all the plastics back in when i first did mine so teey do fit, but you wont be able to fit the ashtray part on
But i preffered it without so removed them again
Soooo need to paint my shift box though!
P1N3R
152
Preston, Lancs
But the ash tray section won't fit on top? I guess it's either higher shifter or trim?
It looks cool anyway, thanks for your time. Is it an improvement having it up higher?
Apr 15, 2009
2,189
Midlands
Ashtray wont fit as the shift box is in the way
I love mine how it is, feels loads better being higher up, main reason i havent fitted the short shift is because i dont want it any lower now
