not that I know anyone about the Derv side of things (petrol person myself), what do they do to the diesel turbo, same thing as they would to a petrol turbo?
360 thrust bearing, largened turbine inlet, bigger turbine wheel etc?
hi mate this is what they did to my turbo :
Stage 2 – MD376
Hi flow GT20 spec compressor wheel, cnc machined compressor housing, 360 degree
thrust bearing, cut back turbine blades, lightening of turbine wheel for faster ‘spool up’,
modified V.N.T. turbine housing, uprated turbine seals. Other ‘blueprinting’
modifications.
it's a din gauge pod off eBay I got one but felt it looked a bit cheap it's just a thin bit of metal that lays on top but I might try And spray mine to match the surround then get some diff gauges
I have seen the gauge holders on ebay, but i got mine from america for about £20 its bit thicker metal than the cheap ebay ones you get. its like a radio panel that clips into DIN socket.
Stage 2 – MD376
modifications.
cool, tis what I thought then...a turbo is a turbo no matter if it is derv or petrol:)
yeah i think they work slightly different as in petrol have negative boost and diesel dont. but generally speaking they are same. Cant wait to get work done now, my turbo just sat in box waiting to be fitted.
thanks mate, i love my beeza so thought its worth spending money on, going to keep it till it falls apart, lol which hopefully will be a long time yet. looking at your sig pic yours is very nice to :) what car is that?
oh forgot about my TT pedals had them so long now as you can see, lol
nice i keep trying to get my self to buy a detailing kit for £90 but keep stopping my self as theres a few more important things to be done first :)
yea i no yours are but yours seem to illuminate better then mine probably got a dodgy one so thought they might of been diffrent :)
i got the seven colour ones, the middle one is an older seris hence it wont keep colour you select. got turbo boost for £9.99 as end of line, volt for £12 and middle one for £13 bargin :funk:
Just a quick thought. Seeing as you have OEM HID's, do you have the washer jets in the bumper too?
If you do, good luck fitting an FMIC.
The pipework runs right were the jet is.
