What's needed when bleeding the brakes fella? You need two people dont you? One to pump the brake while the other one bleeds it? We do it in work but I'm always the one pumping.
if you are not mechanically minded DO NOT attempt this. I hold no responsibility if someone uses this guide to bleed there brakes and it goes wrong.
as you said 2 people min 3 is better. just a quick
guide........
person 1 (p1)= pedal pumper
person 2 (p2)= nipple bleeder
person 3 (p3)= level watcher (person 2 can do this)
p2 get a piece of clear tube and a jam jar or a proper bleed bottle then go to the calliper that is the furthest from the master cylinder. put spanner on nipple then put tube on nipple and into jam jar or bleed bottle.
p2 opens nipple and says down and p1 pushes pedal down slowly. after the bubbles stop flowing p2 locks nipple off and says up..... repeat this a few times. give the pedal a pump and repeat a couple more times untill no more bubbles are coming through.
p3 is to keep an eye on the level all the time topping up as you go (if doing it with 2 people p2 will have to keep checking the level and keep it topped up)
once the furthest one is done work your way back towards the master cylinder. normally the bleed sequence is n/s/r, o/s/r, n/s/f, o/s/f callipers
i hope that makes sence
