Awesome power pal! Is there a Stage 1 and stage 2 DPF delete then?
There is only a stage 2 DPF Delete. Stage 1 is just a generic map with no mods.
Alex
So how come your has produced 60ft/lb more than every other DPF delete then?
I'm the only one to get my dpf delete done at an independant custom code agent in Scotland, aggresive was my request
aggresive he gave me lol, car had 8k on it nd clutch was slipping nd all my exhaust sensors blew lol
Worth it though
Looking good mate, quite like the skirts back-to-front - although will it cause problems if you need to jack the car up ?
Hey mate, yeh i had an angel tuning stage 1 map which made 202 and 321 ft lbs of torque, there is defo a clear difference, for me the power band was broadened throttle response was so much higher and the car revved a lot faster with noticeably more torque and pace, and also a nice sound from the down pipe, i'm gonna get mine RR'd again just after i fit my custom straight through back section, but it's defo a big difference, the only thing i find sometimes apart from an occasional stutter, is if ragging it and change from 4th at 95-100 to 6th i get a slight friction feeling as if the fly wheel is going to fast, it doesn't struggle to go in, just need to be gentle lol
wild lol although it is on/off!
Lovely car matewhere abouts in ayrshire you from because i dont think ive seen your car?
Ok fair enough. What sensors did it blow and how did you solve the problem?
Cheers buddy! What does the EML light look like?
