Black Tdi Ibiza!
Ac2709
124
Blackpool
I was de badging the rear before like i've done with my other cars. The letters on the beeza are so much harder to get off though. Should i use sticky stuff remover? I usually just use hot water to get the adhesive off (N)
Ac2709
124
Blackpool
The tax disk holder is ok, i think i need to spend my money on honeycombe upper grilles first though :)
Can you get the honeycombe lower grille on a pre facelift bumper do you reckon? I'll have to have a look around.
Red Panda
368
Not telling
Just looked actually and found a guide. Definitely need to get the 3 honeycombe grilles!
Give RM Fisher a ring on 01524 751250 and Darren or David in the parts dept will defo help you get the FR grills and all needed. They have been excellent for me and they really go the extra mile. I got my centre sun visor from there so they know about it. I believe some dealers have denied the visor exists! :)
Ac2709
124
Blackpool
I've emailed Sears to see how much they will cost from there, not heard anything yet so might give RM Fisher a call tomorrow. Reckon they will be roughly the same price?
rf860
3,575
scotland
remember this is the weekend so a response is unlikely. David @ Sere will prob respond asap on monday.
Red Panda
368
Not telling
Why not compare?...however you won't have to pay postage from Fishers and they'll get the bits in a day or two for you. Sere seem to have a great reputation on here so either way's going to work I'd say :)
Ac2709
124
Blackpool
Thanks mate. Will give them a call tomorrow about parts. Hope they will be a good price. They change the look straight away :)
Ac2709
124
Blackpool
Even though it was raining i had to get the badges off the back and take a view pictures.
The car is pretty dirty due to not being able to clean it in this British weather :p
Getting the badges off
Badges off
Going to spray this black when i work out how to get the grille off :(
andy17
PD100
May 20, 2009
416
Southport
Looks good mate
The front grill has two clips, you can see them when u open the bonnet, they you need to tug it towards you and it should pop off :)
Ac2709
124
Blackpool
Cheers mate. Had a look before and spotted the clips on the sides to the left and right of the S. However on the top there was two plug sort of things. Don't know how to get these off. Might just have to cut them off!
Hows yours getting on?
Ac2709
124
Blackpool
Today. Been cracking on with some Uni assignments, but decided i needed a little break for the car... :)
Got my new aerial in the post. Not as nice as i was expecting, however its smaller than the standard one...
Before
After
Also took my 'S' grille off. Going to get the grille and badge sprayed up black tonight so i'll hopefully have updates of that later...
andy17
PD100
May 20, 2009
416
Southport
got your priorities right having a break from uni work to play with the car ;)
how did you get the two 'plugs' out from the grill in the end?
when i took them out on the old car i completely destroyed them with pliers lol
Ac2709
124
Blackpool
Just got a flat screw driver and made a lever. Then just popped them both out. They look like i can use them again when i fit it back in which is good :)
Sprayed the badge tonight at my college course (Y)
I'll get pictures up now
Ac2709
124
Blackpool
Guys. Slight problem. I was just changing my headlight bulb and as i was puling the metal spring clip off the hook that holds the bulb in place may have snapped off :(
Any ideas what i should do?? It's absolutely typical :(
