Hehe! Did this over christmas!
Loads fo WD40 on the studs, bottom stud is 17mm other 3 are 16mm
Apart from a standard toolkit, you'll need..
- Turbo to DP Gasket (had to order mine from Seat / VW
dealership but are rare to be on the shelf, call all the local VW / Audi / Seat
dealers in the area with the part number)
- I also ordered 2 studs, the 4 bolts and washers "Just in case" as they're not on the shelf either
- Stubby 16mm and 17mm Spanners (can buy from Halfords and will save you **** loads of time!)
It's not really a
problem taking it off, but as the
reviews state, the DP is MAHOOSIVE! So the angles tightening it up aren't friendly!
My advice would be (if your sig is accurate) to fit the turbo whilst your at it, as the DP basiclly is gonna be 45min to an hours job to take off with all the stupid frustrating angles you have to work at - then you'll have to plum it up back up again. My knuckles are all cut up from the heatsheild so it's a job I won't be doing again in a hurry!
Hope this helps!
